What are the OSC Output commands from ColorSource AV Console?
Question
What are the OSC Output commands from Colorsource Console AV?
Answer
OSC Output is automatic once you have selected an OSC IP and Port Tx in the Network settings. The list is limited to the following strings that get sent when the value changes:
OSC Method Arguments Purpose
/cs/out/ping   Response to /cs/ping
/cs/out/playback/{x}/level Level [0.0-1.0] The current level of playback {x}
/cs/out/playbacks/page Page number [1-10] The current page of playbacks
/cs/out/active/cue/text Cue label (string), cue number (float) The current cue
/cs/out/active/pending/text Cue label (string), cue number (float) The next cue
/cs/out/playback/go Cue label (string) Go has been pressed
