Replacing the Main Playback on a Element 2
Element 2 Console Main Playback Replacement
If instructed and given parts through Tech Services, here are the steps in replacing the Main Playback board on an Element 2 Console.
1)     Remove the Encoder wheel and fader caps. clipboard_ea660822a7e4ca9bae049cdebeefc3c02.png clipboard_ef8a9079573058e0ba202f3f903f0990f.png
2)     Open up the console per: How to Open an Element 2
3)     Clip the two cable ties that are keeping the cable bundles in place. clipboard_e90a873c432639835aea7a9b1f68b092e.png
4)     Disconnect the gray ribbon cable by unlocking the tabs on top and bottom and pulling straight out. clipboard_e2b8a6eaaf6168643f889c7735857f4ad.png
5)     Disconnect the black USB and unplug the yellow and black cable to get them out of the way.  clipboard_e92ebcd2c93f6e9dee0e119a9e3fba611.png clipboard_e4ca6e6fa048db86a76fcb5c5946f26b1.png
6)     Remove the Philips head screws lining the perimeter of the main playback board.  clipboard_e6ff67a9a3cbc378a85a459feb219f3c4.png
7)     Pull the circuit board straight towards you to remove it.
8)     Push the new board into place.
10)  Plug the 3 cables back in, making sure the locks close around the ribbon cable as it goes back in. clipboard_e78efe6a81e634e496fa0f85aac754204.png
11)  Restore the cable ties.
12)  Close the console back up.
13)  Pop the fader caps and encoder wheel back on. clipboard_ea660822a7e4ca9bae049cdebeefc3c02.png
