Tightening Encoder Knobs on Eos Ti Consoles
Over time, the encoder knobs on your console may become loose.  You can fix this by tightening a small set screw holding them in place.
The information below applies to the original Eos Ti and Gio consoles, and not the enhanced versions. If your encoders look like this then this article does NOT apply to your console.  clipboard_edf21883685e82726c594ad14310b42ab.png
Required Materials
  • Coin or flat-head screwdriver
  • Phillips screwdriver
  • 1/16" Allen wrench
How to
Access the Control Panel
  • Lower the display panel all the way down, making the console as flat as possible.
  • Using a coin or a flat-head screwdriver, open the console's face panel via the two quarter-turn locks on the bottom of the console.
  • Lift up on the wrist rest of the control panel like the hood of a car
Loosen the Encoders
  • On Gio, loosen but do not remove the 4 screws indicated in this image:
  • On Eos Ti, loosen the three screws on the Pan/Tilt encoders in this image:
  • For the parameter encoders, loosen one screw between each encoder.  Please note some of these screws were difficult to photograph, but are still indicated in the image here:
Tightening the Set Screws:
  • Gently lower the face panel.
  • Press UP on the encoders and they should push above the surface of the console, exposing the set screw.
  • Tighten this screw using a 1/16" Allen wrench.
Completing
  • Make sure to re-tighten the screws on the underside of the console and re-lock the face panel when done.
