Channels Are Stuck On and Have a Colored Value
I have channels on my Eos Family Console that will not clear.
Eos Family software uses different color indicators to give different information about the channel.
Red: Channel Value is manually captured but not recorded.
Blue: Value in a cue that is higher than the value in the previous cue.
Green: Value in a cue that is lower than the value in the previous cue.
Magenta: Value in a cue that is unchanged from the previous cue (tracked).
White: This Value is blocked.
White with Underscore: This Value is auto-blocked.
Yellow: Channel Value is from a submaster.
  1. Select the channel and press the "About" key.
  2. View the "Source" Column to see where the value for that channel is coming from.
  3. Clear that source.  Use  [Sneak] to clear manual values and [Go to Cue][Out] to clear a cue list.  For a Submaster choose [Sub][x][Out][Enter]. To clear values from all submasters, use [Sub][Home][Thru][Home][Enter].
