Custom Multi-Cell Fixture Profiles adding Locked Value to Master Cell
Symptoms
Whenever I re-open my show or reboot my console, Eos is adding a "Locked Value" to my custom multi-cell fixture profile and adding extra addresses to patch.
clipboard_e36e30e17e1f13fc228d45d021f17f7c6.png clipboard_eeb029373744bf6babef4dd4588a3f1fe.png
As of Eos version 3.1.2, there is a bug in Eos that will incorrectly add a Locked Value to the Master Cell of a custom multi-cell fixture if the DMX offsets are incorrectly set on the Master Cell. This most commonly occurs when the control parameters that control the fixture as a whole are at the end of that fixture's DMX table. It's sometimes helpful to think of the Master Cell as just another cell.
Fix
  1. Remove the Locked Value from your Master Cell and set the DMX addresses for each physical parameter to count sequentially up from 1
Incorrect Correct
clipboard_efd4da284a2f89ab8c8d942e40f0eb44d.png clipboard_ed5105ba28bfb4a94190532cb033fdfdb.png
  1. Tap {Edit Multicell}
  2. Set the DMX Offset for your Master Cell to be the first address of the master control parameters for your fixture
Incorrect Correct
clipboard_e258a328282dc78e51c7fd338525df34c.png clipboard_e04f210d77479efb0c85e9009582575f7.png
  1. Tap {Save Fixture}
