Eos multiconsole status indication
Question
What's the meaning of the green / red / yellow indication next to the command line and User ID ?
Description
Eos family consoles can be operated in various multiconsole / network states. If your console is always used as a "stand alone" device, you would normally start the Eos application as "Primary" (or "Offline" if you don't want to output to the lighting system). In a mutliconsole environment, consoles can also be used as "Backup" or "Client" stations. In Eos version 3.0 "Augment3d Tether" is introduced as an additional network state. The table below explains the meaning of the different indications and colors.
Primary
User 1 | Primary | Master Acting as Master, no Backup connected
User 1 | Primary | Master Acting as Master, Backup connected
User 1 | Primary | Master Acting as Master, lost Backup
User 1 | Primary Knows Backup has taken over control
User 1 | Primary | Master | Tether Acting as Master, no Backup connected, running Augment3d via Tether
User 1 | Primary | Master | Tether Acting as Master, Backup connected, running Augment3d via Tether
Backup
User 1 | Backup | Tracking Backup, tracking Primary
User 1 | Backup Backup, lost Primary
User 1 | Backup | Master Backup acting as Master, has taken over control
User 1 | Backup(Master Busy Loading) Backup indicating Master is busy loading
User 1 | Backup Backup unable to connect to Primary (e.g. because of wrong language setting, fixture library version, etc.)
User 1 | Backup | Tracking | Tether Backup, tracking Primary, running Augment3d via Tether
User 1 | Backup | Master | Tether Backup acting as Master, has taken over control, running Augment3d via Tether
Client
User 1 | Client | Primary Client, connected to Primary acting as Master
User 1 | Client | Backup Client, connected to Backup acting as Master
User 1 | Client | Backup Client, still connected to Backup, but Primary is taking back over as Master
User 1 | Client | Primary(Master Busy Syncing) Client indicating Master is busy syncing (e.g. to another Client, etc)
User 1 | Client | Primary Client unable to connect to Primary (e.g. because of wrong language setting, fixture library version, etc.)
User 1 | Client | Disconnected Client, no longer connected to any Master
User 1 | Mirroring | Client | Primary Client in Mirror mode, mirroring Primary
User 1 | Mirroring | Client | Primary(Master Busy Syncing) Client in Mirror mode, mirroring Primary, indicating Master is busy syncing
User 1 | Client | Primary | Tether Client, connected to Primary, running Augment3d via Tether
User 1 | Client | Backup | Tether Client, connected to Backup, running Augment3d via Tether
