How to Create a Batch of Submasters in Eos and Map Them to a fader wing
Question
In Eos, I want to create a BUNCH of submasters and map them to my Fader Wing at once. How is this accomplished?
Step 1: Create the submasters
  1. Enter the submaster list in Blind by double tapping the [Sub] button.
  2. Syntax: [Sub] [first of the submaster range] [Thru] [Thru] [last of the submaster range] [Enter]. This creates the batch of submasters.
    1. ex: [Sub] [1] [Thru] [Thru] [40] [Enter]
Step 2: Map the submasters to the Fader Wing
  1. Start with a blank Fader Page.
    1. To unmap faders in Live, syntax: [Shift] + [Fader Load Button(s)]
    2. Unmapping faders can also be done on [Tab] [36] Fader Config page.
  2. Syntax: [Sub] [first of the submaster range] [Thru] [last of the submaster range] and then press the [Fader Load Button(s)] of the desired starting fader.
Related Links/References
