How to Import and Delete A Custom Gobo Image in Eos Family Software
Do you have a custom gobo image you had created? You may wish to import that image into Eos in order to use it in a fixtures gobo wheel.  This can be done via the Browser.  The same process is used to delete unneeded gobo images.
How to Import a Custom Gobo Image
  1. Save your gobo image(s) to a USB drive (or on ETCnomad a location on your computer you will be able to find) and insert the drive into your console.
  2. Tap [Displays] (or F9 in ETCnomad) to open the Browser.
  3. In the Browser, expand File, then Import.
  4. Expand Gobo Images and choose the location you have your image(s) saved.  If you choose a folder, all images in the folder will be imported.  If you choose a file, just that file will be imported.  Double click to start the import.
  5. To use these images, when creating a Gobo Wheel in patch they will be found under "Custom."
How to Delete Custom Gobo Images
  1. Tap [Displays] (or F9 in ETCnomad) to open the Browser.
  2. In the Browser, expand File, then Import.
  3. Expand Gobo Images and choose the location [Imported Gobos]
  4. Select an image to delete, then press [Delete] [Enter]
