How to Map Range of Submaster to Faders
I want to map a range of submasters to a range of faders rather than individually mapping.
  1. [Sub] [X] [Thru] [Thru] [Y] and hit the bump buttons for the first fader in the range.
    1. X being the first submaster in the range.
    2. Y being the last submaster in the range.
Note-Icon.png The above solution will work, so long as content is not already mapped to any of the faders already.  To unmap content, hold down [Shift] while pressing the two bump buttons (or load key).
