How to force Go to Cue to use the cue's timing rather than the default Go to Cue timing?
Question
I want my Go to Cue action to follow the timing in the cue, rather than the default Go to Cue timing. What is the syntax to do this?
Answer
Add "Time" to your command. The syntax should look like Go_to_Cue # Time Enter. You can also learn this into a macro, or use the #/ modifier before the cue number to specify a cue list as well.
