Moving lights not consistent with XYZ Focus positions
When applying a XYZ Focus position like for example X Focus, Y Focus and Z Focus = 2 / -1 / 0, my movinglights don't consistently go to the same position on the real stage, however they do in Augment3d.
Explanation of Issue
Movinglights will take the shortest path to a XYZ Focus position. So depending on "from where" the light will have to go to a certain position, the actual output DMX value might vary. Theoretically, it should still result in exactly the same position on stage. However since in reality small offsets in hanging positions (and other factors) accumulate to bigger offsets, the actual focus position might be a little off, depending on throw distance. Augment3d might still show the "correct" spot, since those little Offsets in hanging positions are most likely not 100% accurately entered in the Augment3d drawing.
This is because movinglights usually have a Pan range of more than 359°. Most common is a Pan range of 540°, so 1 1/2 complete turns. Some fixtures even offer a bigger Pan range than that. This means that most positions on stage can be reached in multiple ways.
Example: In both videos below, all lights starts off from a physical (XYZ) position 1, however with different Pan / Tilt values in Video 1 and 2, as you can see in the images below the videos. Then they all move to the same XYZ Focus position (person in the middle of the runway).
Video 1: The yellow and blue lights seem to travel unnecessarily complicated.
Video 2: All four lights take a more optimal path.
Pan / Tilt and XYZ Focus comparison for start positions:
Note: Pan / Tilt Format was used in this example to show the transition in the cues more clearly. Using XYZ Format instead will move the lights in a direct line. The resulting DMX value might still vary however depending on the starting position.
Note 2: An exception is a Focus position directly below a movinglight's hanging position. In this case the Pan / Tilt values will always be "straight down" - usually 50% of it's total range.
The FLIP function found in the Focus Encoder Display area will pan and tilt lights to the same physical (XYZ) position with different Pan and Tilt values. Usually, there are 3 ways for a light to reach the same Focus position:
  1. Tilt direct with minimal Pan
  2. 180° Pan and minimal Tilt
  3. 360° Pan and no Tilt
In the 2nd Video above, the yellow and blue lights were flipped on the start position to improve the travel path to the final position.
