OSC Output Refresh Rate
Description
Eos sends implicit output of OSC under certain conditions.  A common use-case is updates while a cue is fading, showing the time remaining to complete the cue and the percentage complete:
/eos/out/active/cue/text,s 2 6.3 10%
Usually, these updates are sent ~1/sec
However, the Third Party OSC connection, which uses TCP Port# 3037 in v1.1 SLIP encoding, updates ~10 times per second, approximately every 100ms.
