Patch display in Express consoles
The Patch display allows you to create and modify your patch. Patch moving lights in Fixture Patch, covered under Patching one fixture or a fixture range.
Patch area
Lists channels in the first column, dimmers patched to channels in the second and subsequent columns, and the levels and/or profiles assigned to those dimmers. In Flexichannel mode, channels that are used are highlighted.
Profile assigned
Displays the profiles assigned to dimmers.
Level assigned
Shows the levels assigned to dimmers.
