Using an Effect Submaster in Express
An effect recorded to a submaster interacts with cues and other submasters on a pile-on basis. Bring up the effect by pressing the submaster’s bump button or raising the slider.
An effect submaster fades proportionally between zero and the effect’s high level. The slider acts as a master. If the effect’s low level is normally 10 percent, moving the slider to 50 percent will reduce the effect’s low level to 5 percent.
94  See Adding a rate to a submaster for information on changing the rate of a submaster.
