Temporary Change to CS Spot CPU2 Fan in 2022
CS Spot Temporary Fan Change 2022
Due to parts shortages, we had to make a change from a 24 volt fan to a 12 volt fan in ColorSource Spot fixtures. This change was not made on any other ColorSource fixture variants. The replacement fan has the same characteristics as the original, just a different voltage. No change is needed to the software, and will not affect the operation of the fixture. If you have questions, please reach out to Tech Support.
