Troubleshooting Error Codes on Source 4WRD
The LCD on my S4WRD has an error. What does it mean?
Error Code | Description |
OtP |
Indicates the fixture has gone into over-temperature protection. Reset the fixture to clear the code. For DMX mode: Return the DMX control to 0. For AC mode: Remove the fixture from power for five seconds and then restore power. |
UtP |
Indicates the fixture has gone into under-temperature protection. Allow the fixture to warm to a minimum of 5°C (41°F). |
Flashing DMX Address |
Indicates loss of DMX. |
Dark Screen |
Indicates loss of power or fixture time-out. In the event of time-out, press any button to wake the user interface. |
dL / rdy |
Indicates fixture has lost firmware. Reload firmware via UpdaterAtor. This will require either a Net3 Gateway, Gadget II, or USB to DMX Universal Downloader USB Whip. This will also likely require a 5-pin XLR to RJ45 Adapter. |
