Troubleshooting Error Codes on Source 4WRD
The LCD on my S4WRD has an error. What does it mean?
Error Code Description
OtP
Indicates the fixture has gone into over-temperature protection. Reset the fixture to clear the code.
For DMX mode: Return the DMX control to 0.
For AC mode: Remove the fixture from power for five seconds and then restore power.
UtP
Indicates the fixture has gone into under-temperature protection. Allow the fixture to warm to a minimum of 5°C (41°F).
Flashing DMX Address
Indicates loss of DMX.
Dark Screen
Indicates loss of power or fixture time-out. In the event of time-out, press any button to wake the user interface.
dL / rdy
Indicates fixture has lost firmware. Reload firmware via UpdaterAtor. This will require either a Net3 Gateway, Gadget II, or USB to DMX Universal Downloader USB Whip. This will also likely require a 5-pin XLR to RJ45 Adapter.
OPC
Indicates problems with internal cable connections.
Please contact your local authorized ETC service partner for further information.
SHC
"Short circuit": The electronic is detecting a short somewhere in the fixture, Please contact ETC to get the unit repaired.
Related Links
