Pathway Four-Port DMX over CAT5
DMX over CAT5 applications when using a Pathway 4-Port terminal gateway requires an accessory kit (PN SGN1401). Each kit provides four converter cards that plug into the rear of the gateway and allow for IDC terminations. Due to the fragile nature of solid core wire, we do not recommend screw down terminals be used with CAT5. If your job requires you to use DMX over CAT5 and you do not have an accessory kit, please reach out to your project manager.
