Response Mk2 DMX Gateway Versions
Description
The table below lists every version of gateway software (sometimes called firmware) and its corresponding release date.
You can click the release date to download that version's release note.
Related Links
Filter:
Response Mk2 DMX Gateways
Version Release Date Key Enhancements Supported Hardware Software Download
2.1.0.6 July 30, 2024 Adds support for NFC Configuration* through ETC Set Light of:
  • Name of gateway ports
  • Pass Through if On (PTIO)
  • Last Source Only (LSO) Data Loss Behavior
*Two and Four Port non-DIN Gateways only
Response Mk2 One, Two, and Four Port DMX Gateways UpdaterAtor
1.3.1.4 May 26, 2022 Resolves an issue with external security tools Response Mk2 One, Two, and Four Port DMX Gateways UpdaterAtor
1.3.0.3 April 29, 2021
Fixture Update and RDM Improvements, performance enhancements
1.2.0.7 August 20, 2020
RDM and User Interface Improvements
1.1.3.16 February 27, 2020
Updated User Interface and Home Screen Port Indicators
1.1.2.13 January 21, 2020 Bug Fixes Response Mk2 One, Two, and Four Port DMX Gateways UpdaterAtor
1.1.1.9 July 9, 2019 Initial Release Response Mk2 One, Two, and Four Port DMX Gateways UpdaterAtor
Response Mk2 CPU2 DMX Gateways
3.1.0.13 July 30, 2024 Adds support for NFC Configuration* through ETC Set Light of:
Response Mk2 CPU2 One, Two, and Four Port DMX Gateways UpdaterAtor
3.0.0.7 August 31, 2023 Initial Release to support Mk2 CPU 2 DMX Gateways Response Mk2 CPU2 One, Two, and Four Port DMX Gateways UpdaterAtor
