Response 96 In
The Response 96 In (also known as an L86-EMAD) was an Analog to Digital Converter that could convert up to 96 channels of 0 to +10V  or 0 to -10V analog input to either DMX-512 or D192 digital protocols. It was available in a portable or rack-mount version. The rackmount versions could be connected together, up to a maximum of three units, allowing a total of 256 analog inputs to a single digital output.
RESPONSE 96 IN
DMX/D192 DATA PINOUT
Pin Function
1 Common
2 Data -
3 Data +
ANALOG INPUT PINOUT
Pin Function
1-32 Channels (1-32)
35,36 Common
JUMPERS
Jumper Function
J4 DMX/D192
J3 Positive/Negative Voltage
TRIM POTS
Potentiometer Function
P2 Full Adjust
P1  Zero Adjust
Connecting additional units
- RELOCATE J5 AND J6
- REMOVE Z4 ON ADDITIONAL UNITS
Notes
Trims are interactive
1 mA to 10mA/output, 12vdc to 28 vdc max
