ColorSource Relay LED Indicators
Graphical Key
Description Image
Long / Intermittent Blink Blue_Short_LongBlink.png
Normal Operation
ColorSource Relay LED Show ID 201 Show ID 102 Show ID 117 Show ID 133 Show ID 149 Show ID 165 Show ID Set via RDM / Multiverse
CSRM_Label.png ID 1 2 3 4 5 6 C
Green
Cyan
Magenta
White
Red
Yellow
Blue
DMX Present
DMX Present
DMX Present
DMX Present
DMX Present
DMX Present
DMX
Present
No DMX
No DMX
No DMX
No DMX
No DMX
No DMX
No DMX
Output On
Output On
Output On
Output On
Output On
Output On
Output On
Output Off
Output Off
Output Off
Output Off
Output Off
Output Off
Output Off
Signal Quality LtGreen_Signal.png LtGreen_Signal.png LtGreen_Signal.png LtGreen_Signal.png LtGreen_Signal.png LtGreen_Signal.png LtGreen_Signal.png
Sleep Mode
ColorSource Relay LED State
Intermittent Blink
Off
Off
Intermittent Blink
Software Update
Normal Update Sequence
ColorSource Relay LED Initialize >> Update Radio >> Update Firmware >> Complete
Blue Fast Blink
Cyan
Cyan
>> Varies
Off
Off
Fast Blink
Varies
Off
Fast Blink
Off
Varies
Signal Quality LtGreen_Signal.png Off_Short_Signal.png Off_Short_Signal.png LtGreen_Signal.png
Upgrade Error States
Upgrade Failure
ColorSource Relay LED Initialize >> Upgrade Failure
Blue Fast Blink
Red
Off
Off
Off
Off
File Not Found
  • Check USB for the appropriate upgrade files on the root of the USB
ColorSource Relay LED Initialize >> File Not Found
Blue Fast Blink
Magenta
Off
Off
Off
Off
Waiting for USB
ColorSource Relay LED Initialize >> Waiting for USB
Blue Fast Blink
Cyan
Off
Off
Off
Off
Configuration via USB
See Reconfiguring ColorSource Relay Multiverse with an ini file for details on this process.
Successful Configuration Sequence
ColorSource Relay LED Initialize >> Success >> Remove USB >> Complete
White Fast Blink
Green
>> Remove USB Drive >> Varies
Off
Off
Varies
Off
Off
Varies
Configuration Failure Sequence
  • Failed to configure at least one parameter. Remove the USB drive, insert it into your computer, and verify the syntax of the file.
ColorSource Relay LED Initialize >> Failure >> Remove USB >> Complete
White Fast Blink
Red
Off
Off
Varies
Off
Off
Varies
