Updating a ColorSource Thru-Power via a Gadget or USB update whip.
- Download and Install UpdaterAtor Software from our website: https://www.etcconnect.com/Products/Networking/Software/UpdaterAtor.aspx
- Open UpdaterAtor Software and Press SETUP VERSIONS on the right side:
- Device Type = “ColorSource Thrupower” must be = v1.0.2 or higher
If not, press DOWNLOAD ALL LATEST SOFTWARE Button to the right to get it. If this button is missing, then the UpdaterAtor software has not detected an Internet connection. You may need to close this small menu and enter it again if your Internet connection needs to be refreshed. - Once Firmware v1.0.2 or higher is on your computer and listed as above, then go back to the Main Menu.
- Click "USB/DMX Device"
- In the list select "ColorSource Thrupower"
- Select the option for if you have one or more racks. Note if you have more than one on the DMX line then you must select multiple.
The ColorSource Thrupower will then start to receive the update, once it has completed it will reboot.
