Sensor Dimmer Module BTU Dissipation
Sensor Dimmer Efficiency Evaluation
The following table provides information on the thermal efficiency of ETC Sensor dimmer racks. All dimmer efficiencies are measured at maximum current (full load). Note that the watt and some BTU figures shown below apply to single dimmers, not dimmer modules and a module often contains more than one dimmer.
Module Type
per Dimmer
Full Load in Watts
per Dimmer
Watts Dissipated
per Dimmer
BTUs Dissipated
Dimmer Efficiency
per Module
BTUs Dissipated
D15
1,800
56
191.072
96.9%
382.144
D15AF, D15E
1,800
70
238.84
96.1%
477.68
D20
2,400
77
262.724
96.8%
525.448
D20AF, D20E
2,400
119
406.028
95.1%
812.056
D20HR
2,400
259
883.708
89.2%
883.708
D50AF
6,000
237
808.644
96.1%
808.644
D50HR
6,000
543
1,852.716
90.9%
1,852.716
D100AF
12,000
446
1,521.752
96.3%
1,521.752
R20AF 2,400 <2 <5 ~99.9% <10
ELV10 / ELV10-S 1,200 42 143.4 96.5 286.8
Although Sensor dimmers are designed to operate safely in environments with ambient temperatures of up to 104°F (40°C), as with all electronic equipment, keeping the operating environment at cooler temperatures will help improve the service life of the equipment. In order to maximize the efficiency of your dimming system, dimmer room air conditioning should maintain an ambient dimmer room temperature of 68°F (20°C) or less.
Important-Icon.png IMPORTANT NOTE: When calculating air conditioning requirements, keep in mind that the BTU outputs cited in the table above are maximums. The heat actually dissipated may be less. Factors that influence actual heat dissipation include service ampacity, as well as how the dimmers are used and typical loads.
