Foundry Product LED Indicator States
Color State Description Product Notes
POWER LED
Blue Solid Power is OK All Foundry Products
Blue Blinking Incoming power is outside of the operable range of voltage or frequency Foundry Phase Adaptive Dimmer Check Specifications on the dimmer (found on page 1 of the Install Guide) and verify that incoming power is correct.
SIGNAL/ERROR LED
Green Solid DMX Present All Foundry Products System OK.
Green Slow Blinking DMX Absent All Foundry Products Verify that the DMX wiring is correct, and verify that the DMX source is functioning correctly.
Green Rapid Blinking DMX Errors All Foundry Products Verify that the DMX wiring is correct, and verify that the DMX source is functioning correctly.
Red Solid Shutdown due to Overcurrent/Short Circuit Foundry Phase Adaptive Dimmer Dimmer shuts down at an overcurrent of 16A or when short circuit occurs.  To resume normal operation, correct fault, set dimmer to 0% and then return it to the intended level.
Red Blinking Shutdown due to Overtemp Foundry Phase Adaptive Dimmer Dimmer Shuts down when temperature reaches 90°C (194°F), and must cool to 75°C (167°F) before resuming normal operation.
DMND RESP (Demand Response) LED
Green Solid Demand Response Input is closed. Foundry Mini Panel
EMERG (UL 924) LED
Red Solid Emergency (UL 924) state is active. Foundry Mini Panel
POWER and SIGNAL/ERROR Together
Power: Blue
Signal/Error: Red
Slow Blinking Together Device is in Bootloader Mode All Foundry Products Device has no firmware.  Load firmware to device from ETC UpdaterAtor software over the DMX line.
Power: Blue
Signal/Error: Red
Rapid Blink Together Firmware is being received All Foundry Products Firmware load is underway. Unit will reset to normal upon completion.
