Is Foundry Mini Panel Sense Feed Required
Question
I do not wish to run a normal sense feed to the Foundry Mini Panel.  Is this required, or can I use the panel without it?
Answer
The Foundry Mini Panel's sense feed terminal is an optional feature to allow the panel to go into Emergency/Panic mode if/when normal power is lost.  If you do not wish to use this feature, simply set the Sense Enable Switch to the OFF position.
