Swapping the DMX Chip in a Foundry Mini Panel (UFMP)
My Unison Foundry Mini Panel (UFMP) no longer responds to DMX control, but it does still have power. There is good signal on the line, but the panel is flashing the Signal indicator.
Explanation of Issue
This is often indicative of a failed DMX chip. Both the 4 and 8 circuit models of UFMP have a spare chip on board, so this can usually be resolved in the field.
  1. Shut off all circuits feeding the panel.
  2. Loosen, but do not remove, the 4 screws in the corners of the panel. (note: if your panel is flush-mounted, you will need to fully remove the screws.)
  3. Slide the cover sideways to alighn the keyholes, then lift it off the panel.
  4. Remove the two screws securing the high-voltage cover.
  5. Lift the high voltage cover off using the lift pin on the side of it.
  6. Swap the DMX chip (labeled U3, circled in red) with the spare (labeled SPARE, circled in green). Ensure the small indentation indicating pin 1 remains in the bottom-right corner. It is also worth taking note of the serial number, which is on a white label on the inside bottom of the enclosure.
  7. Put the covers back on, power up, and test the panel for functionality. If you continue to have issues, contact ETC technical services for next steps.
