How to update software on a CEM+ module?
First determine the existing CEM+ software version by navigating to [About] and pressing the check mark. Press + or - until the version is displayed. Alternatively you can press the reset button on the CEM+ and the version will be displayed on boot. UpdaterAtor should be able to detect and update CEM+ modules as low as v1.0.0, but if it's not being detected in that program, you'll need to update using the webUI. Both methods are outlined below.
Update using UpdaterAtor:
- Download and install the latest version of UpdaterAtor. This is also included in as part of the Net3 Concert installation.
- While still connected to the internet open UpdaterAtor, and click on Setup Versions in the top-right corner.
- Select CEM+ in the list of devices, and in the bottom left section select "3.1.3.9.0.44" and the corresponding download button. Once the download is completed close UpdaterAtor.
- Plug your PC into the network the CEM+ rack(s) reside on, and make sure your PC is in the same IP scheme as the racks. Next launch UpdaterAtor.
- Select the rack(s) in the list on the first page, and then click "Update." UpdaterAtor will display a progress bar as the software is sent to the CEM+, then the CEM+ will display "Loading New SW Please Wait..."
- Once completed the rack will reboot and will be loaded with the new software.
Update using the webUI:
- Open Internet Explorer, and make sure you've put the IP of the rack into compatibility settings.
- Login using the info below:
- username:
power
- password:
powerpass
- username:
- Click on Configuration on the left side of the screen, then click on "Upload Files"
- If the software is old enough, you may not have an "Upload Files" button, in this case go to
https://[IP Address]/down.htm
- Click the Browse button and navigate to
C:\etc\nodesbin\cemplus.bld
, and then choose the install option. - The CEM+ will display "Loading new SW Please Wait..."
