Saving CEM+ Processor Configuration Files to a PC
Using the Sensor+ WebUI
- Log in to any controller on the network as Power User
- Go to the Configuration Tab on the left
- Click on the File Transfer Icon
- Right-click on "Sensor.rak"
- Select " Save Target As"
- Select Save As Type "All Files"
- Save file to the location of your choice ***
- Select "Save"
- Do the same for the remaining 3 files (Preset.pre, Arch.rm, Panic.pan)
Using a Modern Browser
- Navigate to the IP of any rack in the group/Sensor.rak (i.e. 10.101.101.101/Sensor.rak)
- The fileserver in CEM+ is case sensitive. "sensor.rak" will result in a 404
- Chromium-based browsers will display the config source code. Firefox will show a blank page.
- Right click empty space and select "Save (Page) As..."
- If prompted to save as .rak.xml, etc, delete the .xml portion of the filename.
- Select "Save"
***ETC Tech Services recommends that you create a folder labeled with the job number or job name. Save all four files to that folder.
