Sensor+ Connect WebUI and Internet Explorer
With modern versions of Internet Explorer (Version 11) accessing a CEM+’s WebUI will prompt the following error once logged in: “Unable to find language and encoded login tags in login POST”.
This is due to incompatibility between CEM+'s webUI and modern version of Internet Explorer
To rectify this
  1. Navigate to the tools menu within Internet Explorer (Alt + X)
  2. Navigate to the “Compatibility View Settings” within the menu and click on it.
  3. Add in the IP address of the CEM+ WebUI under “Add this website”, then click add.
  4. Close the "Compatibility View Settings" window.
  5. Reload the WebUI page and login in with the appropriate credentials
