What's the earliest Software Version CEM+ can run and still receive sACN from Paradigm?
Paradigm outputs Draft (revision .45) sACN from 1.0.0 to 1.1.2 versions. From 1.2.0 onwards, it outputs Ratified (revision.46) sACN. CEM+ recieves only Draft sACN starting in software 2.1.7, and will recieve Ratified starting in version 3.1.0. Therefore, to recieve sACN at all from Paradigm, the CEM+ must be running at least 2.1.7, and to recieve sACN from Paradigm versions 1.2.0 onwards, the CEM+ must be running 3.1.0 or higher.
