SmartPack Power Switch
Question
What does the left-most switch do on the ETC Smartpack?
Answer
This switch turns off power to the control board within the Smartpack. This does not turn off voltage that is supplied to the pack through the feeder cable. If you are working with the pack's cover removed, you should absolutely turn off the feeder power to the pack at the service switch to ensure that the pack is safe to work within.
