A Quick Guide to Hog Programming: Starting a Show, Patching Fixtures, Building Looks, and Recording Your Work
The below instructions will walk you through starting a new show, patching fixtures, creating a look and finally recording that look for playback. If you follow the below steps in order you will have created a new show, scheduled and patched fixtures, created a look, and then recorded that look for playback.
Adding Fixtures to the Show:
- Launch a New Show
- Name the Show
- Hit the Finish Button
- Hold down on the Center of the Screen for 2 seconds
- A Menu Window will open
- Select the Fixtures Button
- Last button on the first column
- The Fixture Window will open
- Select the Add Fixtures Button
- 1st button under the word Fixture top left of the parent window
- The Fixture Schedule Window will open
- Type Lonestar (or the fixture you are using) in the Search fixture name field
- The list will filter to High End and display the Lonestar Fixtures
- If the fixture is not appearing please check our Fixture Library Hub
- Click on Lonestar
- A Blue Bar will appear, and the Count Cell will become editable
- Using the Numerical Keypad enter the amount of Fixtures
- We will enter 6
- Hit the Enter Button on the Numerical Keypad
- Hit the OK Button on the Fixture Schedule Window
- The Fixture Schedule Window will close
- Lonestars will be added to the Fixture Window
- Hit the @ Key
- Hit the Enter Key
- The Fixtures Addresses will appear in the Fixture Window
- Close the Fixture Window
- You can either hit the ‘X’ in the top right corner of the Fixture Window
- Or hit the Close button on the top right corner of the Parent Window
- Hit the Clear Key
Note:
- More information about Patching can be found in section 5 of the Hog User Manual
Controlling the Fixtures via the Media Picker:
- 1 Thru 6 Enter
- Hit the @ Key
- Hit the Full Key
- The Fixtures should be at 100% Intensity
- The Clear Key on the Front Panel will light up Red
- Select the Media Picker Button
- on the Last Row
- The Media Picker Window will open
- Use the tabs to select a Color or Gobo
- Strobe is just open or closed
Note:
- More information about the Media Picker can be found in section 10 of the Hog User Manual
Controlling the Fixtures via an Encoder:
- 1 Thru 6 Enter
- Hit the @ Key
- Hit the Full Key
- Hit the Colour Button on the Front Panel
- Top Row of Buttons above the Numerical Keypad
- Turn the Encoder to select a Color
- Hit the Beam Key on the Front Panel
- Turn the Encoder to select a Gobo
- Hit the Position Key on the Front Panel
- Turn the Encoder to Position the Light
Note: to control a single fixture just type the number
- 1 Enter to control fixture 1
- 2 Enter to control fixture 2
- 1+3+5 Enter will control fixtures 1-3-5
Recording a Look:
- Once you have created the look hit the Record Key
- Next to the 7 Key in the Numerical Keypad
- Touch a Choose Key above a fader
- Play the Master
- Hit the Clear Key
- Fixtures will no longer be selected and the output is coming from playback
- The Red LED for the Clear Key will turn off
Note:
- More information about Recording Lists / Cues can be found in section 11 of the Hog User Manual
