Add a Fixture Library to Hog
When a profile request has been fulfilled you will need to add the profile to the Hog OS before it can be patched and used.  The below instructions are for outside a show (at the Hog Start Screen), but you can do this inside a show.
If on a Console you will need to save the Library file to a USB Stick and plug the stick into the console. If you are on PC, you can save the file to your desktop.
Use this guide when:
  • You have a single fixture library for a fixture that has been made by HES
  • A fixture library that was exported from Hog 4 OS v3.9.0 or above
  • A full fixture library has been released, and you want to use it on your console
Steps to Solution
  1. Right-click Copy the Profile
  2. Launch the Hog OS
  3. Sitting at the Hog Start Screen
  4. Select the File Browser Button
  5. A File Browser Window will open
  6. Click the Libraries Folder opening it
  7. Right-click Paste the Profile into the Libraries Folder
  8. Select the Close Button
  9. Launch a New Show or your Existing Show
  10. Open the Fixture Window
    • Setup Key then Shows soft key
    • Hold down on the 4 Logo until the Menu Window opens then select the Fixtures Button
  11. Select the Add Fixtures Button
  12. Select the Select Libraries Button
  13. Click on the Imported Profile and select the Okay Button
  14. Add the Fixture count you require for your event
  15. Select the Okay Button
  16. Patch the Fixture
Note:
  • To return to the Full v5 Library simply repeat steps 11 thru 13.
