Add a Fixture Library to Hog 4 OS
When a profile request has been fulfilled you will need to add the profile to the Hog OS before it can be patched and used. The below instructions are for outside a show (at the Hog Start Screen), but you can do this inside a show.
If on a Console you will need to save the Library file to a USB Stick and plug the stick into the console. If you are on PC, you can save the file to your desktop.
Use this guide when:
- You have a single fixture library for a fixture that has been made by HES
- A fixture library that was exported from Hog 4 OS v3.9.0 or above
- A full fixture library has been released, and you want to use it on your console
Steps to Solution
- Right-click Copy the Profile
- Launch the Hog OS
- Sitting at the Hog Start Screen
- Select the File Browser Button
- A File Browser Window will open
- Click the Libraries Folder opening it
- Right-click Paste the Profile into the Libraries Folder
- Select the Close Button
- Launch a New Show or your Existing Show
- Open the Fixture Window
- Setup Key then Show Button
- Hold down on the 4 Logo until the Menu Window opens then select the Fixtures Button
- Select the Add Fixtures Button
- Select the Select Libraries Button
- Click on the Imported Profile and select the Okay Button
- Add the Fixture count you require for your event
- Select the Okay Button
- Patch the Fixture
Note:
- To return to the Full v4 Library simply repeat steps 11 thru 13.
