Performing a Software Full Install on Hog
Occasionally a full install of the Hog OS software may need to be performed on the console to perform a software upgrade or downgrade.
Note this article does not apply to Hog  PC, DP8000, Hoglet, Nanohog, or Gig Hog
Software does not have to be installed in order, software versions can be skipped if you are updating software on a desk.
A full install will erase all data on a console's hard drive
Ensure all shows are backed up to external media before performing a full install
Steps
  1.  Ensure that all show data is backed up to an external media device, like a flash drive.
    1. What is Saved to a Showfile Vs Console?
  2.  Download the latest Full Install file from the High End website,
    1. Place the file on your desktop or downloads folder, do not place the file on a USB drive
      1. The full install file has a .iso file extension, which is the same for all Hog consoles:
        1. Tour Hog
        2. Stage Hog
        3. Flex Hog
        4. HPU
  3. Create a Full Install USB flash drive
    1. Making a Restore USB for Installing Hog Software to Console(2018 To Present)
  4. Power off the console
  5. Insert the Full Install USB flash drive created in step 3
  6. Unplug all USB devices from the console
  7. Power on the console
  8. Wait for the system Installation screen to appear
  9. To begin the software installation process, press [ Enter ] on the console
    1. If the [Blind] key is flashing, you can hit [ Enter ] on the console
    2. Or use the touch screen or trackball to click the "Continue" button
    3. A keyboard with an "Enter" key might be needed if installing older software
  10. The installation will take ~ 6 minutes to complete
  11. When the installation procedure is complete a "Console Installation Complete" message will appear
  12. Remove the Full Install USB flash drive from the console.
  13. Exit the installation
    1. If the blind key is flashing, you can hit [ Enter ] on the console
    2. Or use the touch screen or trackball to click the "continue" button
    3. Power off the Console
  14. The console will reboot and the newly installed software will now run.
