BIOS Settings, Full Boar 3
Accessing the Bios
  1. Attach a keyboard to the console and power on the console
  2. During the boot process, press and hold the DELETE key
  3. The BIOS Setup Utility will open
  4. Follow the guidelines below to restore the default Full Boar settings per motherboard model
Advantec AIMB-763
Standard CMOS Features
  • Adjust System time and date
  • Legacy Diskette A: Disabled
Advanced Bios Features
  • CPU Feature
    • Delay Prior to thermal: 8 min
    • Execute Disable Bit: Disabled
    • Virutalization Tech: Disabled
  • 1st boot: CD-ROM
  • 2nd boot: Hard Drive
  • 3rd boot: USB-FDD
  • Bootup Floppy Seek: Disabled
  • Small Logo: Enabled
Advanced Chipset Features
  • PEG/OnChipVGA Control: Peg Port
PnP/PCI Configuration
  • Init Display First: PCIEx
Integrated Peripherals
  • OnChip IDE Device
    • On-Chip Serial ATA: AHCI
  • On Boar Device
    • USB Keyboard Support: Enabled
    • Azalia/AC97 Audio Select: Disabled
  • Super IO Device
    • Onboard FDC Controller: Disabled
    • Onboard Serial Port 1: Disabled
    • Onboard Serial Port2: Disabled
    • Onboard Parallel Port: Disabled
    • PWRON After PWR-Fail: On
    • Onboard Serial Port 3: Disabled
    • Onboard Serial Port 4: Disabled
Power Management
  • Wake-Up by PCI card: Disabled
  • Power On by Ring: Disabled
  • PCI Express PM Function
    • PCI Express PME: Disabled
PDF for Full Boar 3 bios document attached below.
