DMX Output boards for Hedgehog, correct service part numbers, outputs 1 and 2 use different part numbers.
The number printed on the DMX Output board, 80030094EF is not the correct service number. It is an un-programmed board that will not work.
The boards get programmed after arriving at High End and given a new number
The part numbers are different for output 1, and output 2, as they are programmed differently and cannot be swapped to the other position.
  1. Use part number 80030127EF for output 1
  2. Use part number 80030128EF for output 2
