DMX refresh rate not changing on Version 2 Internal DMX Widget ports
In a HPU with Version 2 Internal DMX Widget inserted, the refresh rate on DMX coming from the new cards isn't changing.
Explanation of Issue
At the time of release, there was a known bug where the Version 2 Internal DMX Widgets  output DMX at a fixed refresh rate of 44 Hz. This occurs even if the refresh rate is changed in the Processor Settings window.
Please note - the Processor Settings window by default has a refresh rate of 25 Hz.  Despite this, new HPU I/O cards will be outputting at a refresh rate of 44 Hz.
All other outputs (Art-Net, sACN, DMX output from Version 1 Internal DMX Widgets, DMX output from Hog widgets, etc.) will change to the refresh rate entered in the Processor Settings window.
