DP8000, changing displays and blue front panels.
If the display on a blue front panel DP8000 fails and needs to be replaced, or a customer wants to upgrade the front panel to the black front panel.
The display in the blue front panel DP8000s isn't available any longer. The only option is to change the blue front panel to the black front panel and new type display.
The unit will need to come to High End for the repair as the boards inside get reprogrammed with new code.
The part number for the kit which includes all parts is 80430155, for pricing etc.
