Faders on a Hog 4 wing do not work
The faders on a Hog 4 wing do not work.
The wing is not assigned to a playback bar.
  1.  Open the Control Panel
    If inside the show, [ Setup ] ( Control Panel)
    If at start screen, ( Control Panel)
  2.  Go to the "Wings" tab
  3.  For the appropriate playback bar, click the drop down menu for Dock Assignments
    Docking assignment
  4.  Select the wing that you want
    1. If you are mapping multiple wings, you can click on the beacon icon after selecting the wing to light the "Choose" buttons on the wing.
  5.  Tap on Dock
  6. Click "OK"
