External touch screen does not work on Hog 4 console
The external touch screen does not recognize touch input.
When running Hog 4 v3.8.0 and below, only a select few touch screen monitors were supported.
If running Hog 4 v3.9.0 and above, then the touch screen needs to be supported by Windows 7 without any drivers.
  1.  Make sure the touch screen is a supported make and model. This can be found in Chapter 3 in the manual on your console.
  2.  Make sure you are running the latest software version
If you are not using a supported model and running the latest software version, contact High End Systems support
