PCBs, Playback and Program board correct part numbers, HedgeHog, and Hoglet.
The numbers silk screened on the Playback and Program PCB are not the correct service part number. Those numbers are un-programmed boards that will not work.
Use the part numbers below
  1. Use Playback board part number 80040072EF for both.
  2. Use Program board part number 80040071EF for HedgeHog 4.
  3. Use Program board part number 80040073EF for the Hoglet
