Cannot launch a show in Hog 4 OS
A show cannot be launched because the "Launch New Show" or "Launch Existing Show" buttons are greyed out on the start screen.
Usually, this is caused by the "Run Server" not being checked, or there is another show on the network.
  1. Click on Settings
  2. Check "Run Server" box
  3. Hit "OK"
Note that after the 3.14.0 update, this setting can be found in the Control Panel / Startup Tab. (show must be logged off)
If another show is running, the other show's name will appear in the "Connect To Show" section to connect to. If this is the case, the port number will need to be changed.
  2. Change the Port Number
  3. Hit "OK"
