Copy a scene into a cue in Hog 4 OS
How to copy a scene's information into a cue in Hog 4 OS.
This is useful if you want to copy the information that is inside a scene into a cue.
This will not trigger a scene to go or to release. If the scene is updated, the cue will not be updated.
Steps to Solution
  1. Copy the scene into the programmer
    This can be done two ways, via the command line or a mix of the command line and selecting the scene from the scene directory.
    1. Command line syntax: [ Scene ] # [ Copy ] [ Enter ]
      # = the scene number that you want to copy
    2. Selecting the scene from the scene directory:
      1. Open the scene directory
        [ Scene ] [ Scene ]
      2. Turn Guard on
      3. Tap on the scene
      4. [ Copy ] [ Enter ]
  2. Record the information from the programmer into the cue
    [ Record ] [ List ] # [ Cue ] # [ Enter ]
Example
Scene 3 need to be recorded into list 5 cue 10
  1. [ Scene ] [ 3 ] [ Copy ] [ Enter ]
  2.  [ Record ] [ List ] [ 5 ] [ Cue ] [10] [ Enter ]
