Custom fixture does not have latest changes
You made changes to a fixture in the fixture builder in Hog 4 OS v3.9.0 or newer and the changes are not taking effect.
Changes not taking effect is likely due to the revision number of the fixture not being increased before hitting Build Type
  1. Open the fixture builder
  2. Select the fixture that you are trying to use
  3. In the summary tab, increase the revision number
  4. Tap Build Type
