Hog 4 Error: In Order To Perform This Software Upgrade A Full Image Is Required
The following error is displayed:
"In Order To Perform This Software Upgrade A Full Image Is Required"
  • Some Console updates require a full install, Some can be upgraded, refer to the release notes of the software for which options are available
  • Note: A full install can always be done
  • For Hog 4 PC this does not apply, to upgrade or downgrade Hog 4 PC just download and run the MSI file for the version you wish to install.
  1. Perform a full install to upgrade the console
