Hog 4 PC Front Panel Size Adjustment
The Hog 4 PC front panel (Virtual console interface) is too small to use
The front panel is resolution-based. to make the front panel larger, set the screen to a smaller resolution. To make it smaller, set the screen to a larger resolution.
It is recommended to use standard 1920x1080 resolution for Hog 4 PC, 2k and 4k resolutions are not supported.
  1. Press the Windows Key
  2. Type "Display "
  3. Adjust the resolution accordingly
