How to Import your Show File from v3 to v4
The show file I created in v3 software will not load in v4 software.
Starting with version 3.21.0 b3657 the v3 software has an export feature that allows you to export your show files programming.
Starting with version 4.1.0 b3728 the v4 software has an import feature that allows you to import your v3 show files programming.
This gives you a starting point so you don't have to reprogram your entire show file from scratch.
Install Hog version 3.21.0 or higher
Load your Show File
Setup
Shows
Ensure the Current Show tab is selected
Select the Export Show Button
Export your Show to a USB Stick
Install version 4.1.0 or higher
Launch a New Show
Setup
Shows
Select the Import Show Button
Select the Objects you wish to import
After the import is completed be sure to check your show file for the following
Color Palettes
Color Programming
Beam Programming
Position Programming
Effect Programming
Views
Scenes
Cuelist
Notes:
Editors stored in Views will not import
Plots
Once your show file is loaded on v4 it will no longer be compatible with v3 software.
