How to Import your Show File from v3 to v4 or v5
The show file I created in v3 software will not load in v4 or v5 software.
Starting with version 3.21.0 b3657 the v3 software has an export feature that allows you to export your show files programming.
Starting with version 4.1.0 b3728 the v4 software has an import feature that allows you to import your v3 show files programming.
This gives you a starting point so you don't have to reprogram your entire show file from scratch.
  1. Install Hog version 3.21.2 b3662
  2. Load your Show File
  3. Log off / on your show
  4. Setup
  5. Shows
  6. Ensure the Current Show tab is selected
  7. Select the Export Show Button
  8. Export your Show to a USB Stick
  9. Install version 4.1.0 b3728 or 5.0.0 b135 and higher
  10. Launch a New Show
  11. Setup
  12. Shows
  13. Ensure the Current Show tab is selected
  14. Select the Import Show Button
  15. Select the Objects you wish to import
  16. ** After the import is completed be sure to check your show file for the following **
    • Color Palettes
    • Color Programming
    • Beam Programming
    • Position Programming
    • Effect Programming
    • Views
    • Scenes
    • Cuelist
Notes:
Editors stored in Views will not import
  • Plots
Once your show file is loaded on v4 it will no longer be compatible with v3 software.
