How to perform a software full install on Hog 4 consoles
Occasionally a Full Install of the Hog 4 OS software may need to be performed on the console to perform a software upgrade or downgrade.
Software does not have to be installed in order, software versions can be skipped if you are updating software on a desk.
A full install will erase all data on a console's hard drive
Ensure all shows are backed up to external media before performing a full install
Steps
Ensure that all show data is backed up to an external media device, like a flash drive.
Download the latest Full Install file from the High End website.
The full install file has a .iso file extension.
Create a Full Install USB flash drive
Power off the console
Insert the Full Install USB flash drive created in step 3
Unplug all USB devices from the console
Power on the console
Wait for the system Installation screen to appear
To begin the software installation process, press [ enter ] on the console
If the blind key is flashing, you can hit [ Enter ] on the console
Or use the touch screen or trackball to click the "continue" button
A keyboard with an "Enter" key might be needed if installing older software
The installation will take ~ 6 minutes to complete
When the installation procedure is complete a "Console Installation Complete" message will appear
Remove the Full Install USB flash drive from the console.
Exit the installation
Power off the Console
The console will reboot and the newly installed software will now run.
